CYO44Baseball32 wrote:
Nice write up great info! Only one question, with the G37 how would you set this up with the duel intakes. Now I'm looking at a 75 shot wet kit.
You would run dual 35HP shots.One to each intake.
You don't want to exceed a 75 shot. The added pressures will cause problems with a larger shot. Just as well, if you spray too much, you can end up with pooling or puddling, and getting spray when it's not wanted, or detonation. If this is something you're seriously considering, hit me up via email. There are a few things that I can explain over the phone, better than on a keyboard.
infinitgkid wrote:
i mean if it isn't done properly, that No2 will be you primary fuel source when trying to hit highway speeds...
WTF are you talking about? N2O isn't a fuel. It's well, go read the article that I posted. Then you'll understand.
It's an oxygenator. It adds oxygen to the combustion chamber safely. It also has the nitrogen bonded to the oxygen molecule, which help keep the cylinders cool. I could go on for days about this, but go research it. My break time is almost over.
