Timmbo »
https://forums.nicoclub.com/timmbo-u81750.html
Sun Aug 01, 2010 6:58 am
It does indeed work perfectly on my 2010 G37!!! I used a DPDT switch that I purchased from Radio Shack. I simply tapped into the VSS and the Parking Brake wire going to the back of the AV unit. You need to make sure you ground out the bottom two positions of the switch so when the switch is in the "mod" position, the wires to the back of the stereo are actually being grounded.
I just did this mod last Saturday, so this is all fresh in my mind. The 2010 G37 Sedan FSM really helped me to remove the dash pieces needed. I did install my switch just under the driver's side dash.
Keep the questions coming, I am happy to help!
