Amays U G37S »
https://forums.nicoclub.com/amays-u-g37s-u167091.html
Wed Feb 22, 2012 7:40 am
I have no problem with my transmission 2008 infiniti G37 Sport Coupe. It is the 5 speed transmission. 2009 models and up have 7 speed transmissions.
370z/28 meant was that the transmission engine brakes in lower gears, and you can feel the torque, and it braking, a lot. It's not bad, and it doesn't ruin the experience of driving the car, however, people say that the transmissions on the 5 speeds, and 7 speeds, are jerky in lower gears. There has been a fix for the 7 speed transmissions, but I seriously think the clutch in the automatic is very stiff. If you have ever ridden in a 240sx, when the car shifts, it is similar to a transmission upgrade (automatic transmission shift kit), which pushes the car forward when you shift. The G37 is the same exact way, and that's why I think you get the jerky low gear. It is performance based transmission, so the effects of it are a little different from a regular transmission in a camry, or little nissan. Or similar to the new ford transmissions, which is the same affect of 'surging' you forward.
Do not buy any year model under a 2008. 04-07 have oil consumption issues. Not all of them, but something to look out for, if you are buying an older model.
~25k miles on each clutch, everyone is saying. That is why I bought an automatic, the clutch goes out to fast. But, one thing about the G is that the clutch is very soft. Super Soft. I haven't driven a stick in about 2 years, and I had NO problem getting around in a stick shift G37 sedan.
My 5 speed is great. But you will save more gas with a 7 speed. So its up to you. Either way, if you buy a Manual, prepare to change the clutch frequently. I am not a transmission expert, this is just what i've heard and experienced.
