G37 Transmission Fluid has a solvent/choke cleaner smell
PHX08G37
Car: 2008 G37 Journey
1. The dealership serviced my AT 2008 G37 during the 60,000 mile maintenance (5 QT - Matic S Auto). I just looked at my transmission dipstick and it shows there is twice as much transmission oil than there should be. WTF?
2. Plus, the oil has a solvent, brake or choke cleaner smell, it is a clearish/yellowish color.
I am totally scared about what to do.
I have an appt Monday to have the transmission serviced @ 130,000 miles by an independent mechanic, he is going to replace the filter, gasket and fluid. I am thinking about just doing a drain and fill myself! I just noticed tonight when he changed my motor oil he put 5/20 synthetic blend in my car.
I've read the posts on transmission servicing but none cover these two issues (smell and overfilled). I haven't had any problems except recently it seems to have a slow shift.
Thanks for any advice, Linda
Hi Linda, welcome aboard!
Genuine Nissan Fluid (999MP-MTS00P) Nissan Matic-S should be red, so it should look pink on a white dipstick wiper.
Did you check the fluid with the car level, in Park, idling, and warm?
PHX08G37
No I didn't look at it while idling or warm. I will buy some lint free paper and do it today. Should it still be pink after all these years? I canceled the appointment I had on Monday, gut feeling.
Thanks, Linda
60k miles on ATF isn't a lot. In fact, I think the 09 G was a sealed transmission.
You have to check the fluid correctly to get an accurate reading. The smell is still a concern, but a fluid change isn't going to hurt anything.
PHX08G37
Well I can't find the transmission dipstick and can't get ahold of the guy who checked it. Trying to track him down now.
PHX08G37
I found it. Gonna drive it to warm it up then check with a lint free paper. Be back with the results tonite.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
I believe if your vehicle has the 5 speed AT, then there is a dipstick. The dipstick should be behind the engine, slightly towards the passenger's side, near the firewall. You should see the transmission tube sticking up. You'll have to remove the 10mm bolt securing the dipstick.
If you do not see the tube then it's as AZhitman said, it's a sealed transmission, and would need to be checked by a qualified technician.
PHX08G37
Yes, I found it but there was not a 10mm bolt. The transmission fluid went all the way past the dip on the dipstick. It doesn't look burnt but not pink, a light tan color.
PHX08G37
Well, leave a girl in the dark. Ive been screwed over so many times by the dealership - who I used to trust, now no reply to help me make a intelligent Decision? thanks
