There's really no set interval to replace brakes. It's dependent on your driving habit. The standard industry warranty on pads is 12 months/12k miles or they will replace them for free. If you're a heavy braker or you ride the brakes you could just get the bare minimum. If you're light on the brakes or you downshift and use the engine to assist braking you could in theory extend the life of your pads 2x - 5x the standard life. The pad material also plays a role too in brake life.Foxtrot_01 wrote:thanks for all the advice.
what is the usual mileage when you need to replace the pads?
I do a lot of downshifting and replaced my pads at 85k milesFoxtrot_01 wrote:thanks for all the advice.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
