He's 16 and going for his driver's test on Oct.13th. He WISHES he could get his hands on the G!SteveTheTech wrote:The reflash will resolve the issue you outline in some regard. As I mentioned above there may be some time needed to relearn your long term adaptives.
I spent many years working at Goodyear in high school, it was a great learning experience and those are still the only tires I ever purchase.
If you want to get your sons attention put the car into DS mode step on the throttle.
I wish my parents had one of those when I was that age. However as I am getting older I know I would be singing a different tune now. A car that accelerates from a dead stop to 60 in 5.1sec ( http://www.autoguide.com/manuf....html ) should never be in the hands of an inexperienced driver. I had my license suspended in an 89 Accord when I was that age.Pamywyner wrote:
Thanks for the info and I'll def ask about that reflash!
The RE7 is standard on all automatic G37 09+. Whether the car is rwd, awd, or sport model they all share the new 7 speed. I think the only model still using the RE5 is M35x and M45 and it's x model, but that is another thread in a different forum.RichardnVA wrote: How do I know which transmission I have?You mention the RE7R07a, are there different automatic transmissions available for the G37x?Do the x's have a different transmission than the RWD?Before I take it in reflash the TCM, I want check and see if I have the RE7R07a.
Did they end up finding the noise?Did you go with the ester oil?If the noise is at idle I know some models have a reflash for the ECM that adjust the base VVEL positioning and that has a large impact of some of the noises the engine makes. Ahh yet another reflash although this thread covers the only two software adjustments that get the most attention. The audio unit is a different unit and their software is updated frequently with no mention to us.Pamywyner wrote:Mine is going in on Saturday for it's first oil change and to listen to a weird noise in the engine. My husband thinks it's part of the muffler system. ?? We are also going to mention this shifting problem.
Right now, I'm missing my '04 coupe!
Steve, I finally brought the 37x in to get the TCM reflashed. Worked like a charm! What a difference. Thanks for the tip. One minor point for anyone who plans on bringing their car in for a reflash: I told them I would wait for the service and they said it could take up to 2 hours for the reflash to complete. I waited anyway and it only took about an hour, but just in case be prepared.Thanks again!SteveTheTech wrote:Welcome to Nico,
There is an Transmissions Control Module (TCM) reflash for some of the G37s with the RE7R07a transmission. This seems to resolve many of the inappropriate shift characteristics of this transmission. After you have the software updated a few hundred miles may need to be logged to reset the adaptive memory.
