OK I have not gone over the entire thread, but I wish to add a couple things anyway, hopefully the below makes sense and isn't too jumbled:
a) yes as has been speculated here any ester based oil is a group 5 and this is what this is if it is inndeed a ester base stock.
b) This oil came out originally for the VQ37 since it is a hotter running engine than the VQ35.
The REASON Nissan Went to an ester based oil is because it wanted a popular EPA test friendly 5w-30 viscosity grade oil and STILL be able to have great protection for a VQ37 in a sports car application which is the 370Z.
the more you stay with a thin oil (for a performance application 5w-30 IS thin, despite its wide distribtution) the more you need to go to a high tech oil to have thin film break resistance and oxidation resistance,
because this is hard to accomplish with a 5w-30.c) other engines such as many VW and Audi engines have the same need and VW corp solves this by recommending 40 weight s(or in the past even thicker) oils wherever it can .
d) The gent who asked about his G35: no need for you to use this oil unless you do aftermarket turbocharging ,supercharging or anyting else that significanctly alters the oils behaviour in your engine.
e) I have to check with the Nissan Serv Dept but I seem to remember that it is strongly recommended for the 370Z's (perhaps near mandatory) who have the VQ37 engine. They are sports cars and as such are expected to to be run harder than a GT that the G37 is, and yet these 370's are expected to be filled with a 5w-30.
This application was likely the original reason for coming put with this oil.
f) You can duplicate the performance of this oil with any group 5 oil (Redline , Motul) or some of the better group 4 oils. For most applications this will we be overkill.
You can also duplicate this oils performance by going to the next thicker grade at a less high tech oil ( group 4 or even group 3) which will then be cheaper, (and lose a fraction of an mpg in a typical city short run cycle)
g) I have a VQ35 aftermarket supercharged and use a Mobil 1 0w-40 in winter and sometimes year around. (When I'm broke I use Valvoline 10w-40 Durablend year around.) I NEVER use a 5w-30, but I know I
could use a 5w-30 IF it was a group 5 oil.
In summary: great oil but not needed for every car or even every VQ :
a VQ35 or even VQ37 will run great and be protected great by M1 0w-40 (group 4) or similiar.
BUT if you autoX and dont have an oil cooler on a VQ37 this or a similiar oil is almost mandatory if you stay with a factory recommended 5w-30 ....(but if you go to a 10w-40 or some such grade a less high tech and therefore less expensive oil will protect equally.)
Hope this wasnt too jumbled and made sense to folks and this doenst mean I am not recommending
this great Nissan oil I just wanted to explain the how and why a bit.
Fred..
PS: the EPA mpg testing cycle is heavily scewed toward short trip and cold(ish) running fuel economies.
As a result OEMS give the EPA cars with as thin oils to test.
the EPA tells the OEMS they have to tell their users to use a given viscosity if they want to use it in the testing cycle.
This is the reason for OEMS are telling users 5w-30 is the only or at least the preferred oil (some go even thinner).
I have the memo somewhere on an old computer on pdf...
And this is what drives some of the oil spec requirements now of some OEM's which will often mandate a thin running for fuel eoconomy when cold and add this to thier spec sheet what an oil must meet, so publsihed OEM oil spec sheets often are not only specs for protection as most people seem to tink but for fuel economy...
