G37 oem wheel 19 inch
Pierremontreal
Car: Infiniti M37x
Hi, quick question: theses wheels fit on my M37x ? Does anyones have its on their car? pictures? :)
http://www.netcarshow.com/infiniti/2009-g37_coupe/
Thanks you
Ps: I know its better with 20 inch oem wheel but its hard to find in my country.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Yes they will fit.
Pierremontreal
Car: Infiniti M37x
Ok next newbie question, Thoses wheel spec is: 2 front 19x8-1/2 and 2 rear 19x9. Actually is 4 18x8 on my m37x. Can i have any problem if is not the same wheel size?
austin713
Car: 2011 M37
Its not reccommended to run a staggered setup on an AWD system. you are better off finding 4 rears and running it square on all 4 corners.
Pierremontreal
Car: Infiniti M37x
Thanks you! :)
Ilya
austin713 wrote:Its not reccommended to run a staggered setup on an AWD system. you are better off finding 4 rears and running it square on all 4 corners.
Correct, unless you are good at math and can make sure the rolling diameter at each corner is virtually identical. It's not worth the effort IMO.
