Pure white light actually has blue light in it. The key here is it is a small amount of blue light. Moving to a light that has a higher percentage of blue light content, even is seemingly small is still a move towards poorer lighting.
You can look it up on
http://www.danielsternlighting.com.
Further, I emailed him in regards to HID's specifically as his tech and FAQ section talks more about blue lighting with regards to blue filtered bulbs. Here is my question and and his response:
"> I'm curious if you know the negative effects, if any, of changing the > arc capsule of a OE HID lighting system to one of a higher color > temperature.
1. The intensity would be lower.2. The glare would be higher.3. The headlamps' light colour would be illegal.4. The light's effectiveness (from a seeing-performance perspective) would suffer."
He didn't get into the technicals of it, but it seems to reaffirm what he states about blue bulbs in general. It may be to a lesser degree as there will be a great deal of white light compared to that of a blue filtered bulb.
I also asked him a second question out of my own curiosity and it may have some bearing here as well:
"> Secondly, many people claim to perceive bluer lights as brighter. Is > this a result of the same slow pupil-closing response to blue light > causing this percieved increase in lighting?
There are a number of effects at work here. Bluer light is inherently more glaring (per Sivak & Flannagan; referenced in my HID-kits debunk page), and the shift in SPD away from yellow and towards blue does reduce the pupillary constriction."
Coupling this with info he has about yellow colored lights on his webpage strongly suggests that yellower lights are inherently much better for visibility than other colors, most notably blue.
