G37 grill removal
CYO44Baseball32
Car: G37S 6MT
Anyone know the process of removing the front grill?
IP37
Car: 08 Infiniti G37 6MT
it's in the service manual somewhere if you have it
if not i can look through it and see
CYO44Baseball32
Car: G37S 6MT
I looked in the service manual and I can't find anything about it. I looked under the hood and I can't find anything that bolts directly to the grill, it looks like something else would have to be removed first. Any help would appreciated. thank you
IP37
check EXT.pdf..
EXT-19 is about the gront grill
looks like 7 clips holding on the black radiator cover panel on top. use a flathead to get those out, then look like you push that panel towards the rear of the car then tilt it forward and there are some more clips underneath, and you have to unbolt the rad reservoir
CYO44Baseball32
Car: G37S 6MT
yea thanks I found a whole walk-through on the 08 sedan and its simlar to the G37 so it works. I got it out and I'll do a write up on the painting on the grill soon.
audtatious
CYO44Baseball32 wrote:yea thanks I found a whole walk-through on the 08 sedan and its simlar to the G37 so it works. I got it out and I'll do a write up on the painting on the grill soon.
Did you ever get that writup done?
CYO44Baseball32
Car: G37S 6MT
I did its around here some place, I'll post a copy of it up.
audtatious
Make sure SBD knows where it is so we can properly "articlize" it. That and any of your other DIY projects.
CYO44Baseball32
Car: G37S 6MT
I got another nice DIY for everyone, straight Pimp your ride style, no further details will be disclosed yet.
