G37 front tires wear..
LuckyLuke
Car: G37s - HKS Exhaust - R2C Performance Intake
I don't know if my g37 has really bad alignment. The inside of the front wheels are wearing out really fast, and I have little bit over 21K miles on the tires. I have Dunlop tires. What is your experience front tires?
telcoman
When was the last time that you had your wheel alignment and balance checked?
How often do you check your tire pressure?
Telcoman
Starter
Car: 13 G37X sedan
11 G37S sedan
Tire pressure wouldn't cause just inside wear. Alignment would be the first thing to check.
LuckyLuke
I got my tires balanced every 7K, and just did last week. They told me about the front tires wear problem. Since I got the car, I think it was wearing inside more in the front, but not this bad.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Depending on the tire specs, determine the expected wear mileage. The G is notorious for inner tire wear, even in stock form and I always recommend to have front toe set to max toe in to help with this issue.
