I have a few buddies interested in this product for their G37's. I'm finishing up last test fitting for the G37 and I wanted to see if this is something that you guys/gals with G37's would potentially be interested in. If so, maybe we can make an initial group buy for everyone interested.
These are laser cut from 063 aluminum - not only is it lightweight and strong but it is non-corrosive so it won't rust out over time.
These will offer much better protection for your car - especially if you are modded/lowered. Design allows for use of 1" oil pan spacer.
2 or 3 piece design is possible:
2 piece design is a full aluminum piece from bumper to back of engine with a OIL DOOR to make draining and changing the oil filter quick and easy without removal of all 16 bolts.
3 Piece would be like the attached photos for what we have for the G35 - A seperate front piece for the bumper to radiator support AND another between radiator support and the back of the engine. Also it will have the OIL DOOR. Design for 3 piece ensures that you can replace just the front piece in a "fender-bender" and have no need to replace the entire piece.
The finish is brushed aluminum which can be painted easily, or we can have them all powder coated a flat/gloss black.
The pics should give you a rough idea of what it looks like for the G35. There are several changes for the G37 but all in all will have very similar outer design. AWD may be different though, I haven't fitted a G37X yet.
