She's short and the seatbelt at the pillar mount will not go low enough to not be high up at her neck -- not a good place if she's in an accident
She's been back to the dealer and they've said it's adjusted as low as it will go and there is no other solution. I know some years back I'd seen an extension unit that you basically bolted into the pillar and then attach the seatbelt mount that used to be bolted there, to this extension unit. That lowers the whole assembly down for short folks.
With all the modern seatbelt pre-tensioners etc., not sure if this sort of thing would even work, but I thought if anyone had found a solution you folks would have figured it out.
Thanks in advance for any help you have to offer.
