g37 coupe detailed specs
ampsucker
these are from conceptcarz.com. maybe good for a sticky when confirmed?
see entire writeup and review with lots of photos here: http://www.conceptcarz.com/veh....aspx
2008 Infiniti G37 Year 2008 Make Infiniti Model G37 Body Style Coupe Engine Location Front Drive Type Rear Wheel Weight 3610 lbs | 1637.5 kg Introduced At 2007 New York Auto Show
Engine Engine Configuration V Cylinders 6 Aspiration/Induction Normal Displacement 3.70 L | 225.8 cu in. | 3700.9 cc. Valves 24 valves. 4 valves per cylinder. Valvetrain DOHC Horsepower 330.00 HP (242.9 KW) @ 5700.00 RPM Torque 270.00 Ft-Lbs (366.1 NM) HP to Weight Ratio 10.9 LB / HP (Vehicles with similar ratio) HP / Liter 89.2 BHP / Liter Bore 95.50 mm | 3.8 in. Stroke 86.00 mm | 3.4 in. Compression Ratio 11.0:1 Fuel Type Gasoline - Petrol Fuel Feed Fuel Injected Sequential Multi-point Fuel-Injection Block Aluminum Head Aluminum Vehicles with similar horsepower and weight
Gear Ratios 1st Gear 3.841 2nd Gear 2.352 3rd Gear 1.529 4th Gear 1 5th Gear 0.839
Standard Transmission Gears 5 Transmission Automatic with manual shift Final Drive 3.692:1
Optional Transmission Gears 6 Transmission Manual Final Drive 3.446
Dimensions Cargo Volume 7.40 cu. ft. Passenger Volume 85.001 cu. ft. Fuel Capacity 20.0 Gal Seating Capacity 4 Doors 2 0.29 Exterior Length 183.101 in | 4650.8 mm. Width 71.801 in | 1823.7 mm. Height 54.801 in | 1391.9 mm. Wheelbase 112.201 in | 2849.9 mm. Front Track 60.901 in | 1546.9 mm. Rear Track 61.501 in | 1562.1 mm. Interior Front Headroom 39.401 in | 1000.8 mm. Rear Headroom 34.501 in | 876.3 mm. Front Legroom 43.801 in | 1112.5 mm. Rear Legroom 29.801 in | 756.9 mm. Front Hip Room 53.41 in | 1356.6 mm. Rear Hip Room 48.21 in | 1224.5 mm. Front Shoulder Room 37.701 in | 957.6 mm. Rear Shoulder Room 52.701 in | 1338.6 mm. Vehicles with similar dimensions
Suspension Suspension Front : Double wishbones with stabliser barRear : Independent multi-link with stabiliser bar
Steering Rack and Pinion with Speed Sensitive Power Assist Steering Overall Ratio 16.4 Turning Circle 36.101 ft
Brakes Front Brake Size 13.001 in | 330.2 mm. Rear Brake Size 13.001 in | 330.2 mm.
