AZhitman »
https://forums.nicoclub.com/azhitman-u113.html
Thu Oct 25, 2007 1:06 pm
Sport coupe fans rejoice! Infiniti has managed to channel the soul of the hot G35 coupe into the all-new G37 Coupe while adding comfort, performance and style.
And speaking of soul, it’s all about the new 330-hp 3.7 liter DOHC V6 engine and VVEL. That stands for Variable Valve Event and Lift, a computer engine management system that boosts power to 330-hp and torque to 270 lb/ft. VVEL not only provides more muscle, it helps improve fuel economy and reduce hydrocarbon emissions. Motor Trend says to expect zero to 60 mph in 5.4 seconds.
The 6-speed manual transmission makes the most of the power and improved torque. With 270 lb/ft of torque, the six-speed stick is great in traffic. The G37 isn’t picky about gear selection. Give it some gas and you go, even when you forget and start off in second gear. But the five-speed automatic is no slouch either, and it is equipped with steering wheel gear selection for manual operation if desired. The G37 is rear-wheel drive as a proper sport coupe should be. An all-wheel drive G37x is on its way.
Since appearances are important, Infiniti has carefully re-sculpted the G37, retaining many styling cues from the G35 but rounding off a little here and toughening up a bit there. The shape is aero-efficient with a coefficient of drag of just 0.30. One of the tougher touches is the front end with air intakes large enough to feed a military jet. Overall, the design has a nice edginess that enhances the sense of menace without diminishing the cachet.
A very stiff chassis and race-track-tuned suspension (Nurburgring) equip the G37 with cat-like reflexes and the aggressive personality of a junkyard dog. The torque is palpable. Body control rivals that of a pro-race setup. A limited-slip rear differential prevents frustrating inside wheel spin that plague open-diff cars. Traction control always has your back, but the G37 makes it very easy to drive out of dicey situations. Still, the ride in a G37 does not suffer. Its suspension soaks up bumps and keeps its composure on less-than-perfect surfaces, a trait that makes the G37 a good daily driver. And, with 14-inch front and 13.8-inch rear brake rotors, the G37 stops with authority.
The G37 interior is very likeable. There’s more headroom than in the G35 coupe, and the driver’s seat is a marvel by comparison. Leather is standard. The new coupe has much of the high-end interior of the new G sedan with artistic aluminum trim, soft-touch materials and an ergonomically sound control layout. The overall feel is spacious yet purposeful with the sense of an aircraft cockpit. It’s quiet inside. The blue ambient light is very cool. The center stack is clean and contemporary.
The 2008 G is offered in three models: G37 Coupe, G37 Coupe Journey and G37 Coupe Sport 6MT. The Coupe and Journey variants come equipped with a five-speed automatic transmission with manual clutchless shifting capability via the gearshift lever. The "Sport 6MT" version comes only with a six-speed stick.
Standard Coupe and Journey models wear 18-inch wheels while the Sport 6MT rides on 19-inchers. Standard tires in the Coupe and Journey models are 224/50R V-rated (149 mph), but the Sport 6MT comes with lower-profile 225 wide summer front tires with 245 wide rears. Available options include a navigation system, upgraded stereo and a Bluetooth hands-free phone system.
Safety equipment includes dual front, seat-mounted side and curtain-type air bags; four-wheel antilock disc brakes, stability control and brake assist; and a tire-pressure monitoring system.
For driving enthusiasts there is always one crucial question: How does the G37 compare to a BMW? Motor Trend recently published a detailed comparison of the G37 to a substantially more expensive BMW 335i and awarded the Infiniti "a narrow but decisive margin of victory."
At a base MSRP of less than $35,000, the 2008 G37 Coupe just may be the sport coupe bargain of the year. Drive one at your own risk. True love is priceless.
