RED_DET »
https://forums.nicoclub.com/red-det-u7295.html
Wed Jan 19, 2011 10:59 pm
In order to put g37 brakes on the g35, you have to have a custom bracket for the fronts, assuming this is a g35 coupe, if it is a sedan, no bracket necessary. The rear is a direct bolt on. You will also have to modify (cut) the dust shields as they won't be big enough to house 14" rotors. I would recommend some stainless steel lines as well. I will be adding the g37 brakes to my g in a couple months as I already have the brackets, just waiting on my friend to buy the brembo brakes. I can get the g37 brakes new from Infiniti at a discounted price if you are interested.
