SteveTheTech »
https://forums.nicoclub.com/stevethetech-u103802.html
Sat Jun 06, 2009 1:08 pm
I was wondering how long it was going to take to see this question come up.
The RE7 doesn't have an external dipstick. There is a specific procedure that is required to check the fluid but should not be necessary. I remember reading something about measuring the rate at which the fluid drips from the hole is used to calculate the fluid level. It is designed to be life fluid. Although I would have someone check it every 30k or so unless you notice a leak. Jatco did allot of research in updating the very reliable RE5R05A and early results with the RE7 are positive, even in our loaner fleet.
