hernandez5749 »
https://forums.nicoclub.com/hernandez5749-u97426.html
Fri Aug 08, 2008 11:05 am
THE FRONT CAN BE ADJUSTED. JUST IF YOU TAKE IT TO THE DEALERSHIP (GOD I HOPE YOU HAVE THE SENSE NOT TO DO THAT) OR SOME SHOP THAT KNOWS NOTHING, THEY WON'T ADJUST THE FRONT BECAUSE TO DO SO THEY WOULD HAVE TO BREAK OFF A PLASTIC CLIP TO DO SO. THAT LITTLE CLIP IS THE ONLY THING THAT IS STOPPING YOU FROM ADJUSTING THE FRONT CAMBER SETUP. IF YOU CAN'T DO IT YOURSELF I RECOMMEND GETTING YOURSELF A MECHANIC THAT DOES WORK FOR OR WITH NISSAN CARS AND TAKE HIM ASIDE AND TALK. ALOT OF THESE GUYS WANT THE SIDE BUSINESS AND KNOW WHAT TO DO OUTSIDE THE "GUIDELINES" OF THE FACTORY. KNOW THOUGH THAT THIS WILL VOID THE WARRANTY ON THE SUSPENION IF SOMETHING WAS TO GO WRONG LATER ON. MY COUPE IS AN 2005 AND I DID THAT PRETTY MUCH THE MOMENT I GOT IT. I HAD THE FACTORY 19'S WITH THE SPORT TUNE SUSPENSION PACKAGE (WHICH IS NOTHING MIND YOU) AND THREW ON SOME EIBACH SPORTLINE SPRINGS AND SWAYS. LATER ON I COMBINED THAT WITH THE KINETIX REAR COMBO PACKAGE TOE AND CAMBER. MY CAR RUNS GREAT THE WHEELS NEVER HOP WHEN I SMOKE'EM. GOOD LUCK!
