For a reference on a 75 degree clear day on my 2008 xs my stock intake temperature would increase close to 10 degrees when sitting even for short periods at idle. Within a couple of hundred feet or so it would then drop back down close to its running temperature. It would run about 5 degees above ambient.joe603 wrote:The whole "short ram intakes decreasing HP because of heat" argument is BS. There is a constant flow of air while the car is moving...you're not sucking up stale heated air from the engine unless you sit at a stoplight or staging lanes for an extended period of time.
The better short ram manufacturers will have a heat shield. Personally, I like the Stillen.
I would not rule these out by Stillen:lucasnlee wrote:Thanks for the info guys. I've got it narrowed down to either the Injen or Stillen since they both have heat shields. Injen's heat shields don't look like they are quite as good as Stillens, but they use a filter that doesn't need to be oiled so upkeep would be easier. Stillen's shields look like the best around though.
Ya, I don't want those because you have to cut bigger holes and remove the grill to install. I've been reading that a drop in like K&N and a z tube will actually perform better than the short ram intakes....pfarmer wrote:
http://blog.stillen.com/2008/1...sedan/
That is if you really want to do this on a new car.
Perry
Maybe an hour extra work. Still I doubt you will gain much on your 'G' at your normal driving RPMs and in fact they may give up a couple.lucasnlee wrote:
I think I'm just going to get HKS drop in filters, they have good reviews, are non oiled and a lot cheaper than an intake that may or may not increase/decrease HP LOL So many different opinions on the hp and torque with the SRI's.pfarmer wrote:
Perry
Check out this intake, has a dyno test showing better results than Stillen Gen 3, with much easier installation and non oiled filters. If I get an intake it will be this one for sure.CYO44Baseball32 wrote:Stillen Gen3 is the best intake for the 37 hands down, the fitment blows but its best for the car
Looks like a candidate for a slight hood modification to suck from the windshield like the old cars.lucasnlee wrote:
http://myg37.com/forums/intake....html
Ya, I ruled Fujita out for sure. R2C Powerflow is the only intake I am considering based on ease of installation and performance.suby01 wrote:fujita intake is the worst intake you can get for the G35's. ive posted about this a long time ago, its in here somewhere. but to answer your question my opinion no to fujita.
lucasnlee wrote:It appears you wiped out a quote here. Basically I was thinking of what would it take to do an air intake with suck from the windshield area like a couple of the old cars (I was thinking a Chevelle did this)? This intake with its seals would seem to be a good candidate for such a modification to maybe double back.pfarmer wrote:
Perry
I think the theory behind it is the shields contact the hood to create a seal, thus a quasi cold air intake.
Perry
Cowl Induction
Modified by pfarmer at 3:24 PM 7/23/2009
Modified by pfarmer at 3:26 PM 7/23/2009
Stillen Gen 2 looks pretty good, but I am going with the R2C Powerflow intake. BTW, anybody who is interested there is a group buy going on right now, follow the link below. I've done a lot of research and this is the best air intake for the G37, has dyno comparable to the Stillen Gen 3 without the hassle and oil free filters.suby01 wrote:ease of install and fitment and power gains. would be the stillen gen 2 long tube intake. i would not get the cold air the install is way too hard and i would not trust filters sitting right in my grill. hope that helps.
Just go into it for the sound. You may be expecting too much if you believe it'll make your car noticeably faster than a stock one.lucasnlee wrote:Stillen Gen 2 looks pretty good, but I am going with the R2C Powerflow intake. BTW, anybody who is interested there is a group buy going on right now, follow the link below. I've done a lot of research and this is the best air intake for the G37, has dyno comparable to the Stillen Gen 3 without the hassle and oil free filters.
