I would go with the 8.5 inch wheels. The recommended rim width for common 245/45/19 tires is 7 or 7.5 (depending on source) to 9 inch. I believe you would benefit by the reduced weight as well as possibly extra protection the tires would give to the rims.squiggyacfd wrote:
I think you misunderstood me. I already have used the calculators and know that a 245/45/19 tire will be the exact size in diameter as stock. My question is, would you buy 4 wheels at 19x8.5 or 4 wheels at 19x9 for this tire size? Because I am AWD, I was told I could not stagger my wheels like the G37S...ex. fronts 19x8.5 and rears 19x9 or could I, if I kept the same tire size for fronts and rears?????
Based on what I have been seeing from various sites it appears that this is somewhat based on brand. But the minimum rim width appears to be either 7 or 7.5" and the maximum appears to be 9 or 9.5". What seems to be somewhat consistent is the recommended width of 8.5".squiggyacfd wrote:Decided to post here since I am talking about G37 wheels. I have an EX35 and want to upgrade to a 19" wheel. Finishline wheels has G37 refurbs. I want to put a 245/45/19 tire on these wheels to keep the diameter identical to stock. Would you buy 4 of 19x8.5 or 4 of 19x9 G37 wheels for this tire size? Also, please let me know if I am an idiot and these tires wouldn't work at all. I am thinking 19x8.5 cause they will be a little lighter........Thanks in advance
Modified by squiggyacfd at 5:47 PM 5/11/2009
255 would be the absolute widest I'd go on a 9.0 inch wide wheel. And that's going to be 'overhanging' depending on profile height. Like I said the 235s on my 9" are pretty square with the wheel.Tampa G35 Sedan 6MT wrote:I would go with a 9.0 and then use a wider tire like 275 or 265 or even 255
DJ
If yours are 235/35 then the recommend width seems to be about 8 - 9.5 inch. For 255/40 8.5 - 10 inch seems to be the general size recommendations. Anything under 40 profile indicates a 9.5 is in order.biggie wrote:255 would be the absolute widest I'd go on a 9.0 inch wide wheel. And that's going to be 'overhanging' depending on profile height. Like I said the 235s on my 9" are pretty square with the wheel.
Recommended rim width of 8-9.5 inches.biggie wrote:For the record I have 235/45/17 on a 17x9 wheel.
The 'recommended size' I have been referring to is from various tire/rim dealers as well as tire manufactures. Some vary a little bit but most are within a half inch of the rest of the bunch.Sentientbydesign wrote:Anybody want to offer some advice and not just a bunch of opinions?
The difference between the 8.5 and 9 is going to be negligible. The 9 will be slightly heavier and will make the tire look slightly stretched. The 8.5 will be lighter and will probably be flush or slightly bulged.
I would look into which will be more flush with your fender.
Last thought. If you stretch your tires, you run the risk or scraping the wheels more so than if you run a flush setup, or slightly bulged.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
