G37 19" Front Tires on stock wheels - What size can I use?
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
gibbster19
Car: G37S
I've gotten 10K miles out of the Bridgestone Potenzas and want to replace with the Michelin Pilot Sport A/S Plus. Michelin makes the 245/40R19 rear tires but not the 225/45R19 front tires. Is there another size tire that will fit on the front wheels? Thanks for any advice given.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
http://www.1010tires.com and use the tire size calculator. Put in the oem tire size and what size you are looking at. If less than 3% difference than oem, you will be fine.
This info is from the calculator:
245/40/19 fronts
265/35 or 275/35/19 rears
the 225 tire is a bit narrow IMHO for the g37s front wheel and the 245/40 are too narrow for the rears.
hammertime
Car: 08 G37S 06 BMW M3
I have ordered 2453519 fronts on 8.5" wheeland 2753019 on 10" wheel Please tell me I havent screwed this upThat's the same setup on my M3
johnparkyourcar
Car: 03 DG coupe 5AT
i didnt want to start a new thread for just 1 question but what size tires can i fit on 20x8.5? right now i have 245/35/20...
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
