JeromeS13 wrote:Ok. My bad. It does do more than look at wheel rotation, in all. It does have accelerometers.
Regardless, the vehicle can not tell AT ALL that you're running staggered wheels. My point still remains valid that if you keep the same overall tire diameter, the vehicle will not sense a difference...
No need to argue. It will work.
If you change the lateral acceleration of the vehicle it can tell. In fact Infiniti states so:
2007:
If steering angle sensor, steering system parts, suspension system parts, ABS actuator and electric unit (controlunit) or tires have been replaced, or if wheel alignment has been adjusted, be sure to adjust neutral positionof steering angle sensor before driving.
2005:
If the following components are replaced with non-genuine components or converted, VDC OFF indicatorlamp and SLIP indicator lamp may turn on or the VDC system may not operate properly. Componentsrelated to suspension (shock absorber, strut, spring, bush, etc.), Tires, wheels (exclude specified size),components related to brake (pad, rotor, caliper, etc.), Components related to engine (Muffler, ECM, etc.),Components related to body reinforcement (roll bar, Tower bar, etc.).
Note the statement for the 2005 (exclude specified size).
Whether it gives a negative effect, it appears it CAN affect it. On other forums there are statements to the effect that it may cause the VDC to activated earlier.
So again I would consult Infiniti before stating that it will not affect the VDC when Infiniti appears to state otherwise.
For those interested in what can occur with changes such as these look for 'scrub radius'.
Perry
Modified by pfarmer at 11:11 PM 5/11/2009
