SteveTheTech »
https://forums.nicoclub.com/stevethetech-u103802.html
Mon Feb 18, 2013 8:37 pm
That plug doesn't look bad, a little fouled but not enough to cause a miss. That gap is a little wider than it should be.
I'm going to take a shot in the dark and guess that you long term fuel trim setting was about 120, meaning your engine requires 20% more fuel than it should to achieve a stoichiometric burn. Since plug wear is so gradual most never notice the decreased fuel economy and overall performance that happens gradually as any car ages. Using the computer I can watch the numbers and tell you without opening the hood what those plugs would look like (assuming there are no fault codes). If you have a scanner handy (and do not have an emissions inspection coming up) you can try clearing the cars memory, this should help the cars return to a zero set position quicker. Better fuel will also make a difference in your economy, but beware about fuel injection cleaners and additives for the gas tank. What you should do is (safely) drive the car for a few miles in manual mode, pushing the rpms and engine load high but not to an abusive point. You want to increase the engine temperature to burn off the crud that accumulates as a byproduct of an engine with a pcv system and intake valve overlap.
If you (anyone reading this) are one of the drivers that starts to suspect the car is not running well after about 80K miles it probably is not longer in top shape. I have been inspecting almost everything with a first gen VQ35 at about 80 that run a little sluggish. I suggest pulling the plenums apart (not a job for most) and cleaning them (out of the car) and replacing the plugsand intake gaskets a little early on some. Typically those who use low octane fuel and drive mostly short trips around town develop gunk in the intakes and prematurely need plugs. I do not recommend these early to make money, it really does help. As long as you use the right plugs. I've driven so many of these over the years I can tell within a few feet of moving out of a parking space, what the engine is running like (if it is warmed up).
