G35c 19s on G37?
Kazsmir
Car: '08 Ivory Pearl G37S
Looking for some track wheels... this is probably a rather "obvious" a thought, but was just curious, as I don't know the exact wheel specs for both cars off hand...
Thanks
G_whizz
Car: 2010 G37 Coupe Sport
We have a whole wheel and tire section my friend
here ya go!
http://forums.g35club.org/zerothread/342067
joe603
Car: 2014 Durango R/T
I don't think the 19's are a good choice. They are relativly heavy and a bit narrow...plus expensive. Gwoods uses a set of Ford Mustang rims for his track days...
Kazsmir
G_whizz wrote:We have a whole wheel and tire section my friend
here ya go!
Thanks, I tried searching, but searches never like TLAs... =/ Too short to search
Thought this comment was strange...
RED_DET wrote:*NOTE: G37 and G35 coupe offests differ completely. G35 coupe offests are way to aggressive for the G37 and will not work*
There is only ~12-13mm difference from the G37S 19s to the G35c 19s... Doesn't seem "that" aggressive to me...
joe603 wrote:I don't think the 19's are a good choice. They are relativly heavy and a bit narrow...plus expensive. Gwoods uses a set of Ford Mustang rims for his track days...
Well I've already tracked on my stock G37S 19s... just don't want to cause my daily driving tires to prematurely expire...
Rex
Car: None
I believe the G37 19's areF 19x8.5 +43R 19x9.0 +45
and the G35C's areF 19x8.0 +30R 19x8.5 +33
If that's the case, the G35 coupe (Forged Rays) 19's should work, but IMHO, you'd be better off finding some 350Z 6 spoke forged 18's (same widths/offsets) and you could spend more $$$ on tires.
There's also a staggered (18F/19R) forged offering that came on the 350Z, that would work nice. Though tires to support the 19x10 rear could get expensive.
Tampa G35 Sedan 6MT
Car: 2006 Infiniti G35 Sedan 6MT Black w/ Premium & Areo Pkg
1989 Jeep Cherokee 4X4 Lifted and Old School!
I would go with 17's or 18's for the track... Plus tires are much cheaper for them... 17's are really the way to go with little side wall!
Wait.. You have the S right? so you have to go with 18's as the 17's won't fit over the brakes! I think you will have to look and check the clearance. But I think 17's are the smallest that a g35 can go so i don't think they will work on a G37S! and the old G35c with the Brembo's Need 18's as well!
Im sure someone will be able to help!
DJ
Kazsmir
Rex wrote:I believe the G37 19's areF 19x8.5 +43R 19x9.0 +45
True... I've found a set of 19s with 17k mile old tires (getting low) for $600 picked up in good shape... normally I can't find the wheels for that cheap... and 350Z track wheels normally go for more than that as well... just debating...
Tampa G35 Sedan 6MT wrote:I would go with 17's or 18's for the track... Plus tires are much cheaper for them... 17's are really the way to go with little side wall!
DJ
Yeah, I have a few restrictions due to brakes... must be 18" plus, and all... I'm not looking to "race race", just doing some various DE days at the local track... factory tires held up fine (I was fastest in the group, aside from an STI that day)... just want to make sure the offset will clear ok, but by my estimates, I'll actually have "more" front room for the brakes (granted I'm not actually calculating the spokes, just from center offset) than the original wheels... differences are fairly small... =/
joe603
I know that the G37 brakes will not fit on a G35 due to wheel clearance. Not sure if G35 19's will fit on your car....
