audtatious wrote:Post back up what the dealership found the issue to be.
Finally I went to the dealership. Took forever, I know, I'm sorry, but lagged because I moved and a new job etc etc. SO this is what it really was.
Turns out it WAS a bucket shim. This issue effects so many VQ35DE engines it's ridiculous. So want to know what the price is for a replacement of a bucket shim? The price for one shim is about $30 bucks. The labor and replacement parts comes total to...drum roll please... $3000 bucks.
First dealerships listens for the noise, locates the noise in the upper portion of the engine. Then takes off the valve cover to inspect if the repair for the problem can be done by doing that. So just to replace the valve gasket/parts labor at the dealership is $500-$900.
Since they next have to take off the front timing chain cover, take out the cams, remove the shim, replace it, put it back together, it's roughly $3000. Please get yours fixed before a valve gets warped/mushroomed and punches a whole in your block or what not. that will roughly cost $5500 for that repair, since they have to do head work.
SO finally my car sounds great, nice and quiet, it costs me $3000. Sorry people, but that's the verdict. I hope this finally puts to rest the light "tick tick tick" you may have at around 80-100k miles. I know a few G35 owners and 350z owners who have this faint light tick in the upper engine area. Please by all means, change your oil on time, please make sure you have plenty of oil in between, because that is the most common culprit for worn shims. Ask more questions, as I will break down the parts, hours of labor put into this repair when I get time to list it!
