BrandAidDesignG35 wrote: thanks for bearing with me guys.Jeff you always scare me with your stories... but I appreciate your help... you know, I recall reading up on the forums around the time you had some trouble with your truck, do you think the engine/transmission failure was due to the NX 125s?
So, I'm trying to gather a list of everything I need in one quick checklist
No I don't think the NO2 caused the failures but it didn't help. There are plenty of Hemi's that broke the ring land on #3 and most trucks with over 350 rwhp didn't do demand downshifts into 2nd unless they wanted a new transmission. I think it was a combination of alot of things. I was making around 400-450 hp (camed/ tuned/3" dual exhaust no cats/headers/ignition/6.1 hemi intake manifold, valve cover and coil pack) without nitrous on a drivetrain designed for 345 hp.
The Hemi transmission is the same POS transmission DC has put in Jeep Cherokee's and Dakota's since the late 90's. In the Jeep/Dak its a 45rfe in the Hemi its a 545RFE, using computer tricks it becomes a 5spd auto. The problem is for a demand downshift 2nd gear the transmission has to use the 4th gears clutchs/steels. 4th gear is an overdrive gear and these parts are about 3" in diameter vs the 5-8" diameter 1-2-3 clutches.
I LOVED making the truck do demand downshifts into 2nd gear, I knew it was killing the transmission I was surprised how fast. I never did a demand downshift into 2nd on nitrous. Even still the input hubs teeth were almost worn smooth at 57k miles. I could rebuild a 545rfe by myself including pulling and re installing the transmission in a long Sunday. I just got tired of ALWAYS having to work on the truck. I broke the differential 3 times in 57k miles A year later I still have a complete Chyrsler 9.25 master rebuild kit, trac loc clutch kit (limited slip) and 2 bottles of syn gear oil in my garage. I should put it on ebay!
The transmission failed doing a demand downshift into 2nd gear it downshifted BANGED and shuddered then I red lined. Stock Hemi's are set to redline at 5700 rpm mine redlined at 6400 rpm. I think the transmission breaking cracked the ring land on #3.
If you need any help with the install shoot me an email. I've done a few. Just take your time and try to design a system with some fail safes and you should be fine especially with the 50-75 hp shot. Nitrous on its own is not bad for the motor. Its running lean that kills the motor.
I thought of some more advise,
put in 1 step colder spark plugs I think NKG 4306 was what I ran in the Hemi on nitrous.
Water/meth injection is another way to make nitrous safer because the water cools the intake temp and makes the air denser and the meth raises your octane rating and prevents detonation.
It is SO addictive though, when the nitrous comes on the car just flys!!!
Shoot lots of video, I have NO video of my truck running on nitrous. I just have a few pics of the setup
