g35 window problem
opusdos
Car: 2001 infinty g35
I am having a problem with the passenger side window, if you put the key in the lock to unlock the doors both windows will go down. When you lock the doors both windows go up, when you open the passenger door the window go down 1/2 an inch upon closing the window seals, however the window does not operate by either driver or passenger door switch. Has any one have any thoughts on this problem?
1njen
Car: '04 Infiniti G35 Coupe
i have the same problem.... mine doesn't come back up. well i at least i know its not just me.
smockers83
Car: 2006 G35 Coupe
Hmm, you sure you have a G35? They weren't around in 2001.
They do automatically go down/up when opening/closing the doors. That's supposed to happen so it doesn't get caught. I'm not sure if that's what you're talking about or not. As for the switches inside not working, check your fuses and connections on that window motor.
phil4watching
Car: 06 infiniti g35 coupe
i have the same problem sometimes. i have an 06 coupe. its the motor goin bad, or atleast it was in my brothers Z. if im not mistaken some g coupes have a problem with this
joe603
Car: 2014 Durango R/T
Welcome to NICO!!
Check out the G-series FAQ (in my sig, and a sticky in this forum) for help. Probably the window motor.
dfintegra
Car: 2004 Infiniti G35
Someone told me that they took the window motor apart and cleaned it. That fixed the problem for 2+ years. I'm going to try that with mine cause mines just went bad tody.
zozoka1212
Car: 08 Infiniti G35x
It is partially true.
Sometimes after taking it apart and cleaning it would help. Mostly for short run. It will come back. It is either your motor needs to be replaced or the regulator. I think it was Rich who had the switch go bad also.
Good luck with it.
av8or
Car: '07 FX35 AWD ... '06 4runner limited ..... A320 F.O. (my other ride)
i took mine apart.. cleaned the motor and is still good 15 mos. and counting...
SVTCOBRA
Car: 2018 Q60 AWD 2023 F150 4x4 5.0 FX4
zozoka1212 wrote:It is partially true.
Good luck with it.
Mine driver's side would go up, then come down about 1/6th of the way.I used the RESET BUTTON via the FSM. Requires taking the door panel off.Would try this for any window problem first, since it's ez.
zozoka1212
For some reason I was remembering wrong. Not a first time. LOL
I thought you had problem with the switch and either had to clean it or replace it. LOL Can't remember everything. I guess I am getting older.
av8or wrote:i took mine apart.. cleaned the motor and is still good 15 mos. and counting...
Sometimes it works. Mostly it comes back after short period of time. Glad it worked for you. Hope it will work for more people.
