Post by Omen » https://forums.nicoclub.com/omen-u135297.html Tue Jun 02, 2009 5:49 am
Post by pfarmer » https://forums.nicoclub.com/pfarmer-u122323.html Tue Jun 02, 2009 8:11 am
You may be able to turn it (the rotor). I have done this many times in a small lathe for other motors. There are also small electric shops that can do this for you as long as it is not in need of actual replacement.Omen wrote:I am having trouble with the window motor as many others have. The dealer replaced it once under warranty and it is acting up again. I replaced the regulator since it was cheaper but it looks like I have to replace the motor too. Yes I cleaned it when I had the door open. It looked like there was some wear on the outside of the rotor so I think it is just dead.Anyway, does anyone have a good source for parts online? I would rather new since I think the "re-built" will basically be "cleaned" and back where I started. Local Dealer says they are more than $300.Any thoughts?
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
