G35 wheel offset
bullittandy
Car: 2003 Infiniti Q45 70K miles
1999 Infiniti Q45 Touring 180K miles
1997 Infiniti Q45 270K miles (sold)
1997 Infiniti Q45 186K miles (junk-sold)
searched-didn't find it.What are the offsets of a staggered set of G35 wheels. Looking to buy a set they are the 18" and i believe 8" and 8.5" wide but can someone confirm size and offset.
For an extra special treat can someone tell me if they'll fit a 97 Q with 245/45 and 255/45 tires?Thanks
cullenj76
Car: 99 Q45t 04 SRT-4
+30 front and rear
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
cullenj76 wrote:+30 front and rear
theyre 30 front, 33 rear... if theyre the 8s and 8.5s respectively.
CrimsonQ
Car: Purple People Eater
Yes you can run 245/ 255/
But on a G50 if you run 245 fronts I think they might just stick out a lil bit.
Mine are real close on the stock 225's
elwesso
2007 BMW M Coupe
CrimsonQ wrote:Yes you can run 245/ 255/
Mine are OK with 245-40s...
bullittandy
Thanks to all!! If I buy them (don't need them-so i'll have to sneak them past the wife) I'll post pics soon. In addition, If i get 'em I'll have a set of 350Z touring wheels for sale for cheap.
CrimsonQ
elwesso wrote:Mine are OK with 245-40s...
dont we run dif wheels?
Cant wait to see em on a 97
elwesso
2007 BMW M Coupe
yeah I run the 350Z track wheels, you run the G35 wheels, but essentially they are the same wheel as far as width/offset...
cullenj76
Actually they are +30, front and rear. The 19" coupe wheels are 30, 33.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Remembering from the 18x9 +35mm wheels, you should be way good.
FY33 can take more negative offset than G50, by about 10mm.
Doug Bishop
Car: 86' nissan pickup z241 or sumthing just a compact truck
well about wheels umm got 28 inch boggers and 15" rock crawler rims on my lil two wheel drive truck flings mud pretty good never been stuck just needs some more power 86' nissan carburated four cylinder need some ideas for more powerrr!!!!
cullenj76
The G wheels will stick out 23mm further in the front than the stock wheels, and 29mm further in the rear(assuming you have the 16 x 7 +40 OEM wheels).
That should put you about 20 mm away from rubbing the inner fender in the rear and about 30mm from rubbing in the front.
