G35 Weight Reduction Index
Member area: Post up your ride and the modifications to date
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
The following list will be compiled as I weigh the various parts on my 05 G35 6MT Coupe. If you have any information to fill in, please list it, but I am looking for exact first hand weights. Not estimates, or information derived from 3rd party sources.
The goal is to find unnecessary weight. As we all know, the G35 Coupe is quite chunky. Especially the doors.
If someone is interested in doing this for a 1st or 2nd gen Sedan or the G37, please let me know and I'd be happy to help format the information.
Wheels-
19" Forged Rays-
Fronts-Rears-Lug Nuts
Doors-
Glass Window-Inner cover- 10lbsShell-Electronics-Weather Stripping-Speakers-
Mats-
Floor Mats- 7.5lbsTrunk Mat- 6lbsUnder-mat Support- 3lbs
Seats-
D/S-P/S-Rear Upper-Rear Lower-
Engine Compartment-
Plenum Cover-Battery Cover-Stock Intake (Throttle to inlet excluding MAF)-Battery-
Hood-Trunk-
Trunk Contents
Spare Tire- 32lbsJack and tools- 6lbsLeft and right plastic inserts- 4lbs (2lbs each).
Kenrik
Car: Nissan 240SX Coupe
Infiniti G35 Coupe
Nissan Versa Hatch
I don't know where they Hid the 3400+ LBS...
I'm still trying to figure it out
Sentientbydesign
96 I30 - Sold
Me too, Kenrik...me too.
I think the doors are one of the biggest culprits as I can barely keep mine open when on a slight incline. Seats are probably the second biggest.
Cali 2 Balti G
Car: Desert Platinum G35 Coupe
Dodge Ram Quad Cab
Toyota Sequoia
So when will you begin your research?
Sentientbydesign
96 I30 - Sold
I need to get an accurate scale first. Then I need time lol.
This Saturday, I'm helping with the company picnic. Sunday is my drift event.
I'll probably have the wheel weights before Saturday as I plan on weighing them while the tires are being swapped out.
I also have 1 grounding kit order which I need to fill too lol. Busy busy busy.
Beancooker
Car: Current Car: 2024 Tesla Model 3
Past cars: Way too many to list
Hey Nate, I added the trunk contents also. I wouldn't consider leaving them out of my car, but I should have set them in the pit area when I took the G to the track.
smockers83
Car: 2006 G35 Coupe
The 19" fronts reportedly weigh 19 lbs, the backs weigh 21 lbs.
Sentientbydesign
96 I30 - Sold
Thanks Noah. I think I lost a few neurons while making the list and there were other parts that should be on the list that aren't. I'll get to it soon.
Smockers83 (I always think of PB&J when I see your name). I've seen those numbers for the 19s. I want to believe them, but the one thing I've learned on NICO is never take a report and repeat it as fact unless you're sure and since I'll have the opportunity to check this myself, I might as well.
2 reports of the same weight will definately help sceptics more than one
smockers83
Car: 2006 G35 Coupe
Sentientbydesign wrote:Smockers83 (I always think of PB&J when I see your name). I've seen those numbers for the 19s. I want to believe them, but the one thing I've learned on NICO is never take a report and repeat it as fact unless you're sure and since I'll have the opportunity to check this myself, I might as well.
Touche, those numbers came from 350z-tech and I think they're a reliable source for info. And you aren't the first one to think of PB&J...ever since I started getting called by my last name in 6th grade, I've heard that.
USAF_G35_Guy
Car: 2003 G35 Coupe 6MT
USAF_G35_Guy
just do whatever this guy did.....roughly a 600-700lb drop
http://www.race-cars.com/carsa...s.htm
TeflonG35
Car: 2003 G35 Sedan
Thats insane.
Sentientbydesign
96 I30 - Sold
How are they getting 295 ft lbs of torque?
Door issue has more to do with weak detents than anything.
Mine don't even stay open on flat ground.
Sentientbydesign
96 I30 - Sold
The door inserts felt like at least 10lbs. I'm thinking more, but It's hard finding an accurate scale that measures small and large weights accurately...unless I want to dish out serious dough.
coolbratva
Car: 2004 G35
I still can't believe that g only weighs around 50lbs less than 05 mustang gt. I mean mustang was always known as some heavy muscle car. Where g has most of the parts made out of aluminum.
Sentientbydesign
96 I30 - Sold
coolbratva wrote:I still can't believe that g only weighs around 50lbs less than 05 mustang gt. I mean mustang was always known as some heavy muscle car. Where g has most of the parts made out of aluminum.
I'd check the chassis flex between a mustang and a G35, then compare the "luxury" items in both.
The coupe weighs as much as it does because they did a lot to try and keep the chassis stiff (could have been better) and to keep the interior relatively quiet.
I honestly believe there is around 200lbs of weight that can be shaved without sacraficing functionality.
adren77
Car: 2004 G35 Laser Red Coupe 6MT
I'm still waiting for some numbers
Sentientbydesign
96 I30 - Sold
I'm sorry. Grounding kits have been ruling my life.
I'll see if I can convince the wife to let me buy a scale this weekend.
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
I just found this thread in the bowels of the modification database. This is a very interesting concept. I am not willing to blow tons of cash on a scale but I will try to get a bathroom scale for work to weight some things.
I do not believe that a G should be stripped down unless it is at the track. There are tons of weight inside the car but with the additional weight comes the fit and feel of a luxury car.
I know for a fact there are more than 100lbs of wires in the G (I have had to replace all of them). The door panel weights <10lbs, and far less than the window. If you want to cut weight out of the door remove the finisher,window and regulator plate. The center console weights a good 15lbs and the radio has to be ~10lbs. The carpet mat in the trunk is pretty thick and must weight 15-20lbs, plus all the additional stuff in there,tire,tools,and Styrofoam are dense.
Sentientbydesign
96 I30 - Sold
I think the door inserts weigh much more than 10lbs.
Sorry to all who have been waiting on me. Too many other projects. I'll go buy a scale tomorrow.
SteveTheTech
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
You are talking about the door finisher panel right? I just had one of those out two hours ago and I doubt it weighs that much. It very well may but it is not physically heavy. Take the back seat out if you want to save weight.
Sentientbydesign
96 I30 - Sold
The hard plastic interior part of the door that has the handle, cup holder, and little storage area. I'm sure it weighs less on a sedan than a coupe, but when I took the one out of the coupe it was scary how heavy it was. Maybe it's just weight distribution.
SteveTheTech
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
There is nothing to it though I am trying to find out what the exact weight is without having to go to work and explain to people WTF I am doing there on a saturday with a bathroom scale and a coupe.
BrandAidDesignG35
Car: 04 Infiniti G35 Sedan
That would be pretty awkward Just say some technobabble about how weight ratios affect vehicle mpg up to 4.068% with a bla bla... you know the words...
Then explain you're doing some testing for Nico because you are the man, that will shut them up
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
SBD
where's your weight index??
Sentientbydesign
96 I30 - Sold
I'm lazy!!! Wife keeps talking about getting a scale, but we go round and round about what type and whether to get two or not.
I'm sorry. I've failed you *looks down* lol.
tollboothwilley
haha
just go buy a nice one, no need for a great one.
gotta see what you think we can shed off the car
Sentientbydesign
96 I30 - Sold
Did some quick updates to the list. Steve was right about the door inserts. I think the weight distribution makes them feel heavier than they actually are. 10lbs still seems like a lot to me. Especially since it's all plastic (EPS is still plastic as far as I'm concerned).
There's approximately 61lbs that can be shed from the trunk. More than that if you start pulling the formed carpet off the side walls and scrape the sound deadening material off of the metal (NOT RECOMMENDED).
If anyone does ditch those items, just realize you might lose some traction as those items sit right above the rear wheels.
ldstang50
Sentientbydesign wrote:Did some quick updates to the list. Steve was right about the door inserts. I think the weight distribution makes them feel heavier than they actually are. 10lbs still seems like a lot to me. Especially since it's all plastic (EPS is still plastic as far as I'm concerned).
Yup yupFound that out the 'hard' way by getting beat at my first auto-x with the car. I did my thing and removed all the items I could, but the rear was real tail happy. Took advice from a fellow z driver and put it back in, and the rear was more planted.
Return to “G35 and G37 Modification database”
