G35 transmission whine
av8or
Car: '07 FX35 AWD ... '06 4runner limited ..... A320 F.O. (my other ride)
recently iv'e been getting this weird whinning noise from my engine bay... iv'e narrowed it down to the a/c belt tensioner ( i think).. anybody here have the same problem
rmezz13
Car: Had 2004.5 Nissan 350z
Have 96 f250 and mommas 07 Murano
have you tried cleaning it? could try taking a wire brush to the pulley to clean off the dust and dirt, you could even take the brush to your belt. I do it on my mustang all the time. That thing sucks more dirt into the engine bay than air!
av8or
rmezz13 wrote:have you tried cleaning it? could try taking a wire brush to the pulley to clean off the dust and dirt, you could even take the brush to your belt. I do it on my mustang all the time. That thing sucks more dirt into the engine bay than air!
problem is, i don't think the sound is coming from the belt or the belt tensioner... it seems to be coming from the transmission... had my transmission fluid changed today hoping that it will take care of the problem, but alas the "whine" is still there... basically when you step on the gas, there is this whinning sound... even when your'e coasting to a stop, that whinning sound is still there.... don't know what gives
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
I found the drive belts to whine quite a bit as they wear out.
Do a search for threads created by me and I did a write up on how to replace them yourself. Cost is about $50 for both belts. The job can be done in about 1.5 hours.
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
should only take 30 min to change out the belts
Sentientbydesign
96 I30 - Sold
tollboothwilley wrote:should only take 30 min to change out the belts
Removing the underbody and replacing it takes 20+ mins. I also had some issues getting proper tension, so that included tightening the pulley up, turning on the car, driving it around, getting back down under it, and adjusting everything.
I don't have one of those belt tension tools and my daddy never taught me how to change belts on a car
CPV35GT
Car: 2006 G35 6mt coupe
transmission whine...yup have it too. Know mine not the belts, being recent new VQ and new belts...same whine still there under same conditions as you described. I hear it in cabin while driving.
Had whine since new and currently ~30K getting slightly worse. Another thread here suggested possible input and/or output shaft bearing issues if mine continues to worsen. Lots of warranty left so no concern with me if worsens.
But yeah...checks belts first. Easier solution if ends up being the noise.
av8or
thanks for the replies.. i found out the noise was coming from my transmission not the belts... having the transmission replaced... check my other thread...
CPV35GT
^ Read your other thread. Ouch on the cost, but sounds like you're good to go now with no more issues.
