g35 tranni in 03 m45.
caug
how hard is to put auto transmission from 06 g35 sedan to 03 m45.m 45 would be whole another animal.i am thinking doing it after i drove the 06 g35 sedan. it had better gearing, manual mode just grate transmission.caug
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
caug wrote:how hard is to put auto transmission from 06 g35 sedan to 03 m45.m 45 would be whole another animal.i am thinking doing it after i drove the 06 g35 sedan. it had better gearing, manual mode just grate transmission.caug
Do it and let us know!
szh
Car: 2018 Tesla Model 3.
I am fairly sure (but not absolutely certain) that the transmission in the two models are the same: RE5R05A. The difference is in the programming.
Since you would have to use the TCU from the M (to make sure that all the communications from the ECU, sensors, etc. were correct), the point of swapping would be eliminated.
Way more work with little results to show for it, IMHO ... you would be better off replacing the differential for some performance gains.
Z
jamestgk
Car: 2003 M45
sounds like all you need is to remap the M tcu or maybe the G tcu will work in the M
