G35 Tow Vehicle.. What synthetic gear lube best for rear dif.
Road Ruler
Car: G35 sedan prem
I am towing a camping trailer with our G35 and want to go with a synthetic gear lube for the dif. What would you recommend as far as weight and name brand.... thnxs!
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
I would reconsider that if the G35 has a silicon bushing isloated subframe like the larger V8 cars. Definitely add a transmission cooler at the least if you proceed.
qship96
Car: 1996 Infiniti Q45
as for the rear gear oil,Redline gets my top vote for its group 5 polyol ester basestock for max. protection and a slight boost in mpg-- mobil 1 or amsoil are also safe choices
bullittandy
Car: 2003 Infiniti Q45 70K miles
1999 Infiniti Q45 Touring 180K miles
1997 Infiniti Q45 270K miles (sold)
1997 Infiniti Q45 186K miles (junk-sold)
Any synthetic would work, in the same weight as the factory fill.
how much does the camper weigh?
Road Ruler
Car: G35 sedan prem
bullittandy wrote:Any synthetic would work, in the same weight as the factory fill.
Not sure about the exact weight but most of it is aluminum and is a pro set up with custom receiver etc. Towing is such a pleasure with the G. Power, handling, control.... it is all there. We have a large external transmission cooler and brake controller. Two years of towing and all is well. Sweet set up.
