G35 tire feathering problem?
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
IlsG35
Car: 2003 graphite 6speed G35
is there a fix for this tire feathering problem? i have had a lot of older coupes come in to my shop to get new tire because of this probelm, is there something that can be done about it or is it there for good??
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
There is a TSB that Nissan was doing for the z's, which was resetting the toe on the alignment. There has been some research and debate about certain directional tires being part of the culprit as well. Specifically on the g/z and even going back as far as the q45.
infinititech1
honestly...pretty much no fix for it. we aligned cars all the time for it...but never fixed it. negative camber from the factory
Andy_V35Sky_350GT
Car: 2003 Nissan Skyline 350GT
So, your advice would be to just get tire rotated even more regularly than normal? We talking every 5000 kms?
RED_DET
Vendor
2011 Infiniti G37x
yes. I rotate tires every 3-4k miles and just reverse mounted the tires this time around.
IlsG35
so if i were to go as positive as possible, i mean not put it as positive to make it go out of spec. but if i move it right at the line?would it at least help at all u thunk?? i cant rotate my tires front to back because i have staggered tires i can move them from the right side to the left side but thats about it.
RED_DET
Vendor
2011 Infiniti G37x
in order to get any adjustment on camber, you would have to buy adjustable A arms, which run anywhere from 400-800 dollars. Just reverse mount the tires every 3-5k miles.
IlsG35
i do have the arms i got them for $650 from a firend who totaled his G. oh and i have inner and outter tires so reverse mounting them wouldnt do much for me.
RED_DET
Vendor
2011 Infiniti G37x
In that case, take the car for an alignment, have them set the camber as close to zero as possible, maybe just a bit of negative camber and then adust toe. See if that helps your problem.
Q45tech
Unfortunately the high caster compounds and grows [multiples] the negative static camber when the wheels are turned....................Measure your camber changes with turning angles.
IlsG35
Caster for the rear???
RED_DET
Vendor
2011 Infiniti G37x
no caster for rear. you shouldn't be having any feathering problems in the rear.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
