g35 ticking noise?
otaku1010
2004 g35, last night I was parked and noticed a ticking sound coming from the engine. I then pushed the clutch in and the noise went away. When I released the clutch the noise came back. I got the oil changed and the ticking noise it still there. Any idea what this is? Engine knock?
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
Welcome to the Nico,
There are allot of variables here that can effect the level of noise that comes out of your G. If the clutch is stock as are all other components that the primary source of the noise would likely be coming from the transmission input bearing. Depending on the actual level and exact type of noise there are many components spinning at engine speed that can cause some sort of noise. The Gs equipped with the 6 speed are notorious for making noise in neutral.
Check out the G35 section of our little group. http://forums.g35club.org/zeromain
