autotech43 wrote:Regarding the TSB. There are several things the apply to that bulletin. First is to replace both rear parking brake cables, reason being some of them had a tendency to stick and cause the rear brake pads to have a light pressure on the rotors. The other thing we do, replace the brake pad hardware with a new type of spring clips which helps the rear pads stay away from the rotor after releasing the brake pedal. In most cases I have seen, machining the rear rotors was needed due to the pad dragging caused the rotor to overheat and either have hot spots, also the rotor might be bluish in color from being overheated. The final step, after all of the above was performed, you adjust the parking brake cable. In some cases, warranty did take care of the repair, but not always. You shouldnt have any problems if they apply the complete TSB to your vehicle.
Okay, here is what they did to my car:
Replace both E Brake cables, and hardware.
Cable-Brk rr LH-36531-1L005
Cable-Brk rr RH-36530-1L005
Spring Retainer Kit-44083-4u025
The factory was charged $211.45 for the work, $124.89 for labor, and $86.56 for parts. I think it sounds right for what you said. Although I don't see mention of them adjusting the parking brake cable, maybe this is something done without mentioning of it. Also, should they have caught this the first time when I told them the rear brakes were humming? Or is this TSB rare enough that they could have missed it.? Thanks for your reply, I just wanted to know that they did the needed work this time, which it appears they did.
Brent
