By rydwhite
2003/2004 G35 Sedan
Engine: 3.5 liter V6 (VQ 35)
Drive Type: Rear-wheel drive/Optional All-wheel drive (G35X)
Horsepower: 260 @ 6,000 RPM
Torque: 260 lb-ft @4,800 RPM
Suspension:Front: Independent, forged-aluminum multi-link with coil springs over ripple-control shock absorbers, stabilizer bar.Rear: Independent, forged-aluminum multi-link with coil springs, outboard ripple-control shock absorbers, stabilizer bar.
Valvetrain : DOHC, 4 valves per cylinder with microfinished camshafts and Continuously Variable Valve Timing Control System (CVTCS) for intake valves.
Intake system: High-flow induction system
Compression ratio: 10.3:1
Brake Rotors: 11.7” x 0.9” front rotors/11.5” x 0.6” rear rotors
ABS Type: Computer-controlled 4-channel, 4-sensor with Electronic Brake force Distribution Assist
Turning Diameter: 36 feet
Wheels:Base, Leather Model: 6-spoke 7” x 17” aluminum-alloyLeather, 6mt Model: 5-spoke 7” x 17” aluminum-alloy
Tires:Base, Leather Model: 215/55R17 V-rated all-season performanceLeather, 6mt: 215/55R17 w-rated performance
Wheelbase: 112.2
Overall Length: 186.5
Overall Width: 69
Overall Height: 57.7
Track (front/rear): 59.1/59.3
Coefficient of drag: 0.27 Cd/0.26 Cd with Aero
Head Room (front/rear): 40.1/37.9
Leg Room (front/rear): 43.6/33.6
Shoulder Room (front/rear): 56.4/55.5
Hip Room (front/rear): 52.2/54.1
Interior Volume: 98 cubic feet without sunroof/95.5 cubic feet with sunroof:
Cargo Volume: 14.8 cubic feet (11.8 when equipped with full-size spare)
Curb Weight:Base Model: 3,336 lbsLeather Model: 3,369 lbsLeather 6mt: 3,398 lbsAWD Leather: 3,677 lbs
Fuel Capacity: 20 gallons
2003 EPA Fuel Economy Estimates (City/Highway):Auto 18/266mt 20/27AWD 17/24
2003/2004 G35 Coupe
Horsepower: 280 @ 6,200 RPM
Torque: 270 lb-ft @4,800 RPM
Suspension:Front: Sport-tuned independent, forged-aluminum multi-link with coil springs over shock absorbers, stabilizer bar.Rear: Sport-tuned independent, forged-aluminum multi-link with coil springs, outboard shock absorbers, stabilizer bar.
Valvetrain: DOHC, 4 valves per cylinder with microfinished camshafts and Continuously Variable Valve Timing Control System (CVTCS) for intake valves.
Intake system: High-flow tuned induction system with micropolished tract and ports
Fuel Delivery System: Sequential multi-point fuel injection
Brake Rotors:Standard: 11.65” x 0.94” ventilated front rotors/11.5” x 0.63” ventilated rear rotorsBrembo: 12.76" x 1.18" ventilated front rotors/13.07" x 0.87" ventilated rear rotors
Turning Diameter: 37.4 feet
Wheels:Standard: 6-spoke 17” aluminum-alloyPerformance/6mt Model: 7-spoke 18” aluminum-alloy
Tires:Standard: 225/50R17 V-rated all-season front235/50R17 V-rated all-season rearPerformance, 6mt: 225/45R18 W-rated front245/45R18 W-rated rear
Wheelbase: 112.2
Overall Length: 182.2
Overall Width: 71.5
Track (front/rear): 60.4/60.6 with 17” and 60.4/60.8 with 18”
Minimum Ground Clearance: 6.3
Coefficient of drag: 0.29 Cd/0.28 Cd with Aero
Head Room (front/rear): 39.2/34.7
Leg Room (front/rear): 43.8/31.4
Shoulder Room (front/rear): 53.7/52.7
Hip Room (front/rear): 53.6/48
Interior Volume: 86.6 cubic feet without sunroof/84.9 cubicfeet with sunroof
Cargo Volume: 7.8 cubic feet
Curb Weight:Base Model: 3,416 lbsLeather Model: 3,422 lbsLeather 6mt: 3,435 lbs
All info taken from Infiniti.
