RED_DET »
https://forums.nicoclub.com/red-det-u7295.html
Thu Jun 07, 2012 8:41 am
For boost applications, safe reading under WOT would be 11.8-12.0. 12.5 is the most ideal, but also on the border of causing detonation. In order to adjust the AFR, you would have to put the car on a dyno and have it tuned with tuning software. The stage 2 kit properly tuned should pump out at least 350whp. You really need to have the car put on the dyno and see where its at before you can determine where you can go with it power wise.
