Alt.ImaCoupe »
https://forums.nicoclub.com/alt-imacoupe-u104112.html
Thu Feb 19, 2009 4:23 pm
Looks just like the one I got. Did it come with some templates to locate the holes on the trunk? They look like long thin pieces of thick paper with a hole in the middle. You take them gently onto the underside of the spoiler so that the holes in the paper line up with the holes in the spoiler. The position the spoiler on the trunk where you want it, tape the paper firmly to the trunk, then lift off the spolier, leaving the paper still attached to the trunk with the holes indicating where to drill.
The only difficulty I had was that the holes ended up in the support ribs for the trunk, so I had to drill them out a bit larger to get the washer and bolt through. Once you drill the metal, put a bit of paint or rustproofing on there, especially underneath cause the water does run under the spoiler a bit.
