G35 shuts off randomly and won't start
Slide2unlock
Car: G35 coupe
96 240sx kouki
93 240sx hatch
92 240sx coupe
I have a 2003 g35 coupe, it was rear ended 3 months ago, didnt trip any airbags etc. just finished putting it back together. It ran for a solid like 2 minutes then shuts off and it won't start again, it just cranks, the fuel pump kicks on etc. idk, no check engine light or anything, while it was sitting it had I battery in it, so I wanna say it's the nats system? But I only have one key for it so idk how I would go about fixing that. Any idea on what else it could be and how to fix it?
Slide2unlock
Car: G35 coupe
96 240sx kouki
93 240sx hatch
92 240sx coupe
Well it started again, but yet again only runs for 2 minute intervals every couple hours or so. Idk what it could be, I really need help
Slide2unlock
Car: G35 coupe
96 240sx kouki
93 240sx hatch
92 240sx coupe
I timed to exactly 1 minute 38 seconds each interval. And it only work every 2 hours. It isn't my cas, so what could it be? Does it sound like the nats system?
telcoman
Slide2unlock wrote:I timed to exactly 1 minute 38 seconds each interval. And it only work every 2 hours. It isn't my cas, so what could it be? Does it sound like the nats system?
Welcome to NICO
In order for an internal combustion to function you need:
1- Air
2- Fuel
3- Spark
If I had to make a guess I would guess your problem is :
2- Fuel or the lack of it
Try a fuel pump pressure test as I suspect the fuel pump has a malfunction or a poor electrical connection.
Since you were rear ended and the fuel pump and its associated electrical connections are in the rear the problem may be there?
Do a search on this site for your FSM and follow the troubleshooting steps.
fsm-list-for-your-g-t525067.html
http://www.nicoclub.com/FSM/G35/Coupe/2003/fl.pdf
http://www.nicoclub.com/FSM/G35/Coupe/2003/ec.pdf
See page 48
Good luck
Telcoman
Slide2unlock
Car: G35 coupe
96 240sx kouki
93 240sx hatch
92 240sx coupe
Has fuel, 40 Ish psi, it's like it's on a timer for 1 min 38 seconds
