G35 sedan V35 06 rear wheels offset
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
QX1
Car: INFINITI G35 2006 6MT
Oem 06 sedan 18x7.5 ' wheels offset is marked by factory as 45 mm. can i use 48mm offset in rear? i guess wheel goes 3 mm inside? i think playable range is 43-47mm? is 48 too much?
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
