Rangertom »
https://forums.nicoclub.com/rangertom-u151303.html
Thu Jan 14, 2010 3:06 pm
If you have a 2007 G35 Sedan and the sunroof stops working and makes grinding noises when you try to activate it, the motor mounting bolts are probably lose or even all the way out. After about 38,000 miles, my sunroof would not close and made a nasty grinding noise. I went into the headliner and noticed the drive motor was hanging down and 1 of the 3 bolts was actually all the way out. After getting the headliner down enough I was able to reset the motor position compared to the plastic rack that drives the sunroof open. The task that took the longest was figuring out how to drop the headliner without breaking off fasteners/tabs.
