Bernard V. wrote:As long as the engine is warm the car will start but once cooled off and in cold weather il will not crank or start. Other caracteristics of the problem: The headlights and tail lights were flicking really quickly as engine was off and no keys in ignition ( once ) . The same happenned ( once )with the indicators above the clock. When the engine starts ( milder weather) several indicators light up and gradually dissappear. (The engine service soon indicator as well. ) The codes results are ;can-comm circuit ( u1001)can comm circuit ( u1000) vent control valve ( p0447)nats malfunction (p1615)I need help figuring out what part needs to be replaced first...I should tell you as well that the car has a distance car starter wth no anti-start device. Can the broblem de related to it...Has anyone had this problem already and what was the solution...? Thanking you in advance
There are several things that can cause the u codes. They all have different definitions with generic descriptions. The vent ctrl valve and NATS malfunction are not good. I would not suspect the components themselves.
The NATS code is most likely a by-product of either low reserve capacity in your battery and in the fraction of a second from the point when you turn the key and the time the RFID number is registered with the security unit (BCM) if the battery voltage is too low to support adequate signal transmission a DTC may set.
The vent control valve may be one or two of several possibilities. Given your location and vehicle age I would suspect the valve may indeed be bad they tend to rust when exposed to salt climates. This also may be a by-product of a bad ground, all of these DTCs may be set by a corroded or incomplete ground.
If there is no transmission from the combination meter or any control unit for that matter a U code can be set. These require slight above basic diagnostic skills and I do not know if it will be easy without a Consult handy.
