RED_DET wrote:As long as you can verify maintenance records, I see no issue with buying from private party. You will more than likely get a better deal to boot. Yes you can purchase an extended warranty if the vehicle is still under manufacturer warranty. Infiniti power train warranty is 6yr/70k miles.
I purchased a used 04 coupe with 44K miles on her summer of 2008. Also purchased an extended warranty thru my local Nissan dealership.
Just make sure you are comparing apples to apples....take into consideration the tires, brakes, etc. Some dealerships will replace these before selling. An individual might not.
Trust no one, inspect for yourself.
