G35 Metallic Noise
tcs7363
Car: 03 g35 sedan
Hello, I have an 03 G35 sedan w/ 120k. The car is in very good condition w/ lots of power and shifts well. Automatic.
However, when I first start the car and begin to drive as the car shifts gears, low speed I hear a metal on metal sound coming from the front drivers side. The sound does not occur again unless I have just started the car and begun to drive again. If I am driving come to a stop etc it does not happen, only after first starting and going. It is a very annoying sound.
Anyone else have this happen to them? After the noise it drives like a dream.
Thanks
tcs7363
Car: 03 g35 sedan
anyone?
joe603
Car: 2014 Durango R/T
Welcome to NICO!
not sure on that one....I'd have a dealer look at it.
SVTCOBRA
Car: 2018 Q60 AWD 2023 F150 4x4 5.0 FX4
Heat shield??
I would get up underneith it and shake/bang on the exhaust and anything else to see if I could manually reproduce the sound.
tcs7363
Car: 03 g35 sedan
I have found numerous people who have this issue. Say it is the ABS Purge self-check.
audtatious
Yeah, I was thinking it had to do with the front brakes adjusting itself.
SVTCOBRA
tcs7363 wrote:I have found numerous people who have this issue. Say it is the ABS Purge self-check.
Cool! yeah, if it is a quick one time deal each time then probably it. First few times I heard it I was like WTF!!!! :gapteeth:
tcs7363
Car: 03 g35 sedan
Yes, I was like $%*&^%!!!!
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
shouldn't sound like metal on metal though...its more of a ABS simulation sound than a clunking/clanking sound.
timmy0257
Car: 08 Infiniti G35 Journey 5AT
-R2C Intake
-interior LEDs w/ tag lights
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
Future Mods include GT-Spec strut bar & more.
could it be that your calipers are not releasing? in other words, the break pads are still slightly rubbing the rotor? you wouldnt hear this wth higher speeds because of road noise/engine RPM
