cfschreib »
https://forums.nicoclub.com/cfschreib-u82153.html
Sun Nov 25, 2007 8:38 am
I have a 2004 G35 Coupe with a manual transmission and about 49,000 miles. A few months ago I started to have intermittent problems going from 1st to 2nd. At any RPM you could "feel" a slight gear mesh. I took it to the dealer for an oil change and had them check the problem, they found nothing wrong! But, just in case, I had them change the transmission fluid. Now, about 3,000 miles later, the problem has gotten worse; about every 3rd shift from 1st to 2nd. This only occurs at RPMs below approximately 2,500 and only going from 1st to 2nd. Down shifting is fine?
Any suggestions?
