G35 Low tire indicator strange problem
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
jeffmarmus
Car: 2004 Infiniti G35 Coupe
Good day all, I'm new to the site as I just purchased a 04 g35 coupe last week. Sorry if I'm re posting but I couldn't find anything about this in search. When ever I go for a ride longer than a half hour, the tire pressure light comes on. I checked all the tires and they're at 35 psi. Once I turn off the car and turn it back on it goes away. This is kinda strange because the tire pressure should go up after driving you would think. The car does have aftermarket rims on it... 20's and the back's are wider than the front's. Would that cause any problems?
biggie
The older TPMS are a bit crazy at times. Never heard of this exact problem though. Usually they just cut on when the temp drops the first time in the year.
audtatious
Did you get 35psi with the tires cold or when the light comes on (hot)?
jeffmarmus
That was hot, I read them again with a better gauge and they were at 32ish. So I put them to 38, would the warning light turn on at that high of a pressure?
audtatious
Set them at 32 cold and see if that does not solve the problem. When tires get hot the psi goes up.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
The problem is a battery is going low in one of them. Mine does the same thing on a long trip and I know the tires are properly inflated.
jeffmarmus
That makes good sense. Does that mean I need a whole new sensor or can the battery be changed? Thanks for your help!
RED_DET
Vendor
2011 Infiniti G37x
I'm sure the battery can be changed, but trouble shooting which one will have to be done at the dealership.
audtatious
Hmm...I didn't think about the battery.
telcoman
jeffmarmus wrote:Good day all, I'm new to the site as I just purchased a 04 g35 coupe last week. Sorry if I'm re posting but I couldn't find anything about this in search. When ever I go for a ride longer than a half hour, the tire pressure light comes on. I checked all the tires and they're at 35 psi. Once I turn off the car and turn it back on it goes away. This is kinda strange because the tire pressure should go up after driving you would think. The car does have aftermarket rims on it... 20's and the back's are wider than the front's. Would that cause any problems?
Irecently got rid of my 06G35 and during the almost 7 years I went thru 6 TPMS sensors. Most were covered under warranty.
Have the dealer check them and replace any defective ones or perhaps replace all of them.
http://www.tirereview.com/article/86584 ... eries.aspx
Telcoman
TST SEE
Car: 04 Infiniti G35
Did you get the issue fixed I am having same issue?
telcoman
RED_DET wrote:I'm sure the battery can be changed, but trouble shooting which one will have to be done at the dealership.
Batteries cannot be changed.
The tire pressure sensors are sealed inside the case with epoxy.
The sensors also need to be paired to the correct wheel.
Some vehicles have sensors in the spare.
They transmit an RF signal in the UHF band (312mz) and any interference in the vehicle such as car chargers can prevent the RF signal from reaching the antenna behind the glove box which then sends the signal to the ECU
Telcoman
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
