MaximA32 »
Thu Jun 26, 2008 3:40 pm
I'm not 100% sure but I believe that there is a drain plug for the transmission on the G. All you should need to do is pull that to drain it. Keep in mind that will not get all of the fluid. You will need to drop the pan and re-seal it in order to get most of the fluid out. You will also have fluid still trapped in the lines.
