G35 Help Please
s_rico13
Car: 2007 Infiniti G35 Coupe
New to these forums but figured I would try to get some advice here.
I have an Infiniti G35 Coupe(2007) and am having issues with my Slip light coming on as well as the engine losing power causing bucking/jerking. This originally happened over a year ago for the first time and didn't happen for months after, now it happens within a five minute drive.
Slip light always comes on, ABS light has appeared once recently but no other lights that I remember seeing. Car is pretty much undrivable and I'm at the point now where I can tell when it's going to happen, the engine sounds like it's making a "whirring" sound. Couple other things I've noticed which I hope provide more insight to the problem are reduced gas mileage as well as a distinct smell upon startup. Took it to a local mechanic and he reset the steering angle sensor, cleaned the wheel speed sensors, and replaced my front right wheel hub assembly. I kind of figured I was wasting my time with those repairs but he just seemed stumped to the point where he told me to send it to an "infiniti" dealer.
Side note: I've been researching similar problems to mine and have topped off fluid level multiple times to no avail and I believe my brakes are okay still.
Anyways, sorry for the long post but I would greatly appreciate any feedback.
Gilley
What are you doing just before the problem starts? Is the car a manual or automatic?
Soes the Service Engine Soon (SES) light come on?
telcoman
s_rico13 wrote:New to these forums but figured I would try to get some advice here.
I'll give you my opinion which you may not like
s_rico13 wrote: Took it to a local mechanic and he reset the steering angle sensor, cleaned the wheel speed sensors, and replaced my front right wheel hub assembly. .
That was mistake #1
s_rico13 wrote:This originally happened over a year ago for the first time and didn't happen for months after, now it happens within a five minute drive.
Why didn't you have the vehicle checked for any codes at that time?
s_rico13 wrote: Slip light always comes on, ABS light has appeared once recently but no other lights that I remember seeing. Car is pretty much undrivable and I'm at the point now where I can tell when it's going to happen, the engine sounds like it's making a "whirring" sound. Couple other things I've noticed which I hope provide more insight to the problem are reduced gas mileage as well as a distinct smell upon startup.
You may have more than one problem?
If it was my vehicle I would have had it checked out by a qualified Infiniti technician.
Giving an Infiniti to unqualified and untrained people who call themselves a mechanic usually ends up costing more both in time, aggravation, and loss of use of vehicle
Good luck
Telcoman
s_rico13
Gilley wrote:What are you doing just before the problem starts? Is the car a manual or automatic?
Car is an automatic, and I'm just driving usually around 35-45mph when I can feel a loss of power and the humming or whirring noise. Once this happens, the car starts to buck or jerk until it comes to a stop and will continue to do so until I restart the car.
No service engine light.
s_rico13
That was mistake #1
Good luck
Telcoman
Appreciate it and trust me I wish I had taken it to an Infiniti mechanic right away.
telcoman
You may want to invest in an OBDll reader
They are not expensive
Photo taken when I had my previous 06 G35
Starting an automotive library might help you also.
Telcoman
