G35 Help Fast!!!
04G356MT
Car: 04 G35 6MT
OK I just bought a 04 G35 Coupe about a month ago with 40000 miles on it. I thought I was getting a great deal when i bought it but now im not so sure. My problem is im in the military and the car has to sit for 2-3 days without ever running and today on my way home as i was driving i looked down at the guages and i notice the temp gauge is reading really uberly hot so as soon as i see it i pull over and kill the car, i pop the hood nothing is leaking. nothing is hot, i check the fluid and its full and even its not too hot, the resivoir is fine, so i start the car back up and it still reads hot but drops back to normal very fast so im like ok, i hop in drive a few miles and it does it again, but this time i check something else and dont pull over i drive a little ways and the car drops back to normal droping a peg on the temp gauge about ever 30 sec, i myself think it may be the sending unit going bad, but i need other opinions and would like to know if this would be waranty work, I need help fast as this is my only car at the moment and need it working right
Q451990
I have heard issues of air pockets in the G35 if the coolant is replaced and not "burped" properly. It might be worth downloading your FSM at http://www.phatg20.net or checking your owner's manual to see what you can find out about the process. Do you know of any recent attempts to flush or change the antifreeze?
Heath
qship96
Car: 1996 Infiniti Q45
take it to the dealer,it is under warranty
04G356MT
Car: 04 G35 6MT
well what is it then lol, if its just air ill fix it. beats driving 2hrs to a dealer
ScottJackson
Car: 91 Q45, 92 Q45a, 93 Q45, 79 BMW 635CSi, 95 BMW 540i
I wouldn't drive it at all until I figured out what the issue was. If it was just the sending unit, then it'd probably be OK to drive for a bit if needed to get by until fixed. However, if it's a bad air pocket or sticking thermostat, you could crack a head VERY easily... and that would not be fun.
Q45tech
When you purchased this 40k used G did you get written proof of required oil changes so that the Nissan warranty is maintained.......30k service etc.
A few of the MTcoupe have oil usage problems...........always good to frequently check oil level until you know for sure you don't have one.
qship96
I have a neighbor {young girl} with a g coupe-she starts it up and accelerates hard on the cold engine every morning,causing plumes of thick black smoke to emit from the exhaust-makes me laugh at her stupidity daily
Q45tech
She'll just sell it and some poor innocent guy will think he got a deal.
